Iroc_g
- 173
- 2
- Dec 22, 2004
Burnsville,
Minnesota
Well. I finally got my car running good, and went to make a few full logs with dsmlink. I went WOT in 2nd gear, 2000 rpm, and ran it to about 7000, then hit the 2-3 shift. It didn't feel like it went all the way in, so i re clutched it and slid the shifter in all the way up. It grabbed just fine, I ran it to about 6000 when i car came around the next corner, so i backed off and put it in neutral.
After I got back to 50mph, I went to put it in 5th, but the shifter wouldn't go. Same for all other gears. I was able to rpm-match, and get it into gear without the clutch, so i limped it back to work. Seeing it would go into gear with out the clutch, i assumed either pressure plate, or clutch hydraulics.
That night, i went to go home. I tried to start the car in first gear, and holly crap the noise!!! I popped it into neutral, and tried again. Still noise like hell. It honestly sounds like the started not disingaging!
Any ideas on what i broke? I tried re-bleading the clutch, and it didn't do anything. I can see the clutch fork moving, and it seems to move the same it always did. I also peeked in the botom of the bellhousing, and didn't see anything abnormal. Although,m the outside of the tranny case seemed wet, but i don't know if that is unrelated, because i have a breather leak on the valve cover, and since i was rapping on the car, it night just be from that!!
Thanks for any help!
