i think i have a fuel cut issue?
kazdombrowski
32
Oct 20, 2010
Lancaster, Pennsylvania
Hey guys ive looked and looked at some posts up here and i cant seem to find whats up...
history= 95 talon tsi awd. bone stock minus carbon fiber hood..
I was on my way to advance to get some oil today with a buddy of mine thats back from college and i was in 3rd around 5k-6k rpms and about to shift when bam! my car decided to buck a couple times, i shifted into 4th and everything was fine..
I've read about it being boost leak or plug wires, but i just replaced my wires, and i did a boost leak test and everything was good... should i replace my plugs?
WOT (it happens in the high rpms in 4th gear also just found that out), it was literally like a second before i was planning to lift my foot to shift haha.. i have no tuning devices.. and how would i check the wastegate actuator?
Sounds like a boost leak and fuel cut. Did you happen to section off your Boost leak test to just the charge system and then the intake manifold/other stuff?
Also, check your fuel delivery. When's the last time you've checked your fuel filter?
I get the same thing on mine but it will do it in other gears as well when wot. I have a set of accel 8mm wire on mine that was installed by a previous owner. Anybody running them without any problems. My other dsms I ran magnacore and never had any problems.
