I really need help
ozz9186
Jul 9, 2011
vancouver, Washington
Here gose I have a 92 eclipse with a 91 2.0 nt I can crank it all day long no start I have fuel spark and compression I am lost. The car had a 1.8 befor the swap it has been down way too lOMG please help the motor is a 6bolt it came out of a 90 but I swaped in a 92 cas with a 92 wire harrness and a 90 eprom ecu
Did you change the pins around, there are two wires 6 and 14, i would look at vfaq.com for more information, that could be a problem or your coolant temp sensor, are your plugs flooded?
I took a screwdriver in tje spaek plug wire and it arcs agent the tb grate spark and I have changed tje 6plug with tje 14 plug
Plugs are new I bought them when I bought my starter alt and wires
I am thinking it is the cts could that cause.the injectors to put more fuel than needed
On the nt harness the pin on the 92 harnass is 14 and swaped it to 6.is this wright
I have a 92 eclipse with a complete rebuild and I cant get it to start ive changed ecus changed the cas changed the t.b. I cant seem to get it to run I have grate spark im getting fuel and im getting compression what can I do to get it to run
