i need some transmission help please
b00stboy
Feb 11, 2010
Orlando, Florida
Hey guys I'm in the process of my engine swap and I have a couple of tranny questions that i need to find out b4 this friday... ok does the 2.0 non turbo transmission bolt up to the 1990 gsx motor? If so can I use the 1990 flywheel? If i use a 2.0 tranny do i need to change my shift linkage cables?
i believe they are interchangeable. i do no you will need to change the flywheel. if you are putting a non turbo trans on a turbo engine you need a turbo flywheel and turbo clutch.
and just to let you know the non turbo transmissions gears are much shorter than the turbo one.
ohhh one more thing make sure your axles fit the transmission if your using diff axles.
Really? I heard opposite about the turbo clutch not fitting.. But ok thank you I will try it out
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
