i have a 96 talon tsi awd it has a 4g63 motor in it.
joshua_082
Jan 28, 2011
frenchville, Pennsylvania
i cut my o2 sensor on my car well it was runnin now it not runnin too good. if anyone nos what it could be let me no... and the boost gage stopped workin at the same time i cut the o2 sensor.. thank you
Well it was runnin when it got cut... So i wasn't sure if it would have burnt it up or not???
You...got under the car and cut the Rear O2 Sensor/Heater wires while the car was running?
I forgot about the heater..it's maybe possible then, I can't remember off the top of my head how much juice runs through that circuit, and I just don't know.
Yes i was dumb and cut it we'll it was runnin cause it was one of them nights... i just wanted to see if anyone could help me out???????
some people dont deserve to have a turbo car... not to mention a inexperience semi mechanic... for the love of dsm... replace that o2... junkyard= put it in your pocket and be done... also the stock boost gauge is trash.. get a real one....
I went to the junk yard and they only have 2 1993 talon fwd r the o2 sensors the same or is there another car that has the same o2 sensors??:confused:
Shell out the money for a new O2 sensor, install it, observe what happens, and report back.
It seems you're too cheap to buy a new O2 sensor, which means you're to cheap to do maintenance. This means you should sell your car, immediately, without driving it again.
There's a good chance a junkyard O2 sensor will be bad too.
Im not tryin to be cheap im waitin for the auto part store to get it in they said 4 days till it gets there...
Im so cheap but i got new plugs and wires and change the oil... But u tell me that all im tryin to do is get my car running till the new o2 sensor to come...
I replaced the o2 sensor no luck.. It dont try to start it just truns over but no fire...
I couldn't have said it any better than pur97tsifwd. Lets all take a few moments to pray to the dsm gods that this guy comes to his senses and either sells or fixes this car before it turns into a lawn ornament. If you're really serious about keeping it you need to start using the search option it might prevent you from making another mistake. As for the o2 sensor did you make sure its plugged into the plug that's under the drivers seat. If it isn't that might be where the problem is. Good luck hopefully you can figure it out.
It is pluged in... Im tryin to get it runnin so ican sell it to someone that knows more about it.
I put new plugs in and still nothing it gettin good spark just wont start. Anyone know what it could be?:confused:
:banghead:I put new plugs in and still nothing it gettin good spark just wont start. Anyone know what it could be?
O2 sensor end up gettin cut on the car well runnin. I replaced it now im gettin codes po100 po105 po110 po115????? I dont understand could it be my ecu??? It takes awhile to start then it only ides at 800 rpm??? :banghead:
Well you guys where no help... But i did fine out whats wrong with it. It has a Blown Sensor Ground in the ecu...
