420A I can't get the block off of the trans?
My friend, I mean this in the nicest possible way: if you can't remove an axle then you have almost no chance to rebuild an engine and have it run for any extended period of time. Please consider having someone helping you with this.
To answer your question, I pop my axles out by inserting a flathead screwdriver in between the axle and the transmission and I tap on the handle with a hammer. This will usually pop the axle right out.
Go ahead and take the whole strut out. Remove the 3 bolts up top and where it bolts to the control arm. That bolt with the big washer on it is for the subframe. Don't remove that one. You need to take the axle out of the knuckle first and then pop it out the trans. Use a large screw driver or pry bar and pop the cup out the trans. It has a small clip that holds it in
