ProjectFastazz
- 38
- 0
- May 28, 2004
Ravenswood,
West Virginia
so i bought a motor off a guy said it had been rebuilt and stroked.
i got it home, was in the car. pulled the motor.
pulled pan, looked for main caps to be clearances, they wasn't. So i read that some crolwer rods didn't need cleanaced. can anybody tell me what are stamped or cast into the crowler rod caps.
the crank, has been balanced.
the only info i have is the crank is stamped closest to flywheel on counter weight PD then on the next weight over 55.
and the pistons have that grid looking design on them, like a stock piston. but different markings than the factory piston i had laying around.
NOT SURE WHAT YEAR ROD PISTON I HAVE THAT I WAS LOOKING AT COMPARING TO TO THE MOTOR. From parts way back
the numbers i could see on the underside of the skirt is 43234
any help would be appreciated on this.
NO pictures as of yet.
thanks, Justin
thanks, Justin
