Need help identifying Cams
19BLACKGST98
711
3
Nov 6, 2003
McKinney, Texas
A friend gave me a set of cams but he did not no which brand or size they are. He said he thought they might be BC cams but he wasn't sure (they are not because there is no BC stamp on them).
Any help would be appreciated.
This has 185 etched into it: (they are etched in both cams in the same location)
Well tinypic decided to stop working so I will upload the other pictures later.
Other things I noticed on the cams:
1. On the end of the intake came there is a number: 109302317
2. Close to the dowl side of the intake came there are single A's on each side one being realy big and the other being smaller with a 1 near it.
3. Then closer to the cam sensor side there is a big 30 marked on it and on the opposite side of that there is a big 1.
3. Right next to the cam sensor notch there is a 1 with a 2 under it.
4. Only markings on the exhaust cam are: 05 stamped with a 9 stamped underneath, then on the other side 07 with R3 stamped under that.
Apparently tinypic is only going to let me post one pic a day :(
  • Wanted 6 bolt NT water pipe
    • chrisman287
