420A I’m trying to find a shifter cable and mount
Maxbassett
Jul 16, 2021
Saint Petersburg, Florida
So on my 1997 eclipse rs the shifter cable and mount went out and I’m new to the dsm community so I wanted to see what opinions I could get from the community on where I could find some or if I’ll have to fabricate it and I thought it would be smart to come to the people who know the cars
when you say "the shifter cable..." I assume this is an automatic trans car? The more details you give, the better the help you'll get. I suggest you start with Performance Partout for this kind of item. A decent used one should be perfectly adequate for repair. If you actually have a manual trans, then the condition of the cables is more critical, since every shift employs them. If you happen to go the fabrication route, make sure to share your experience with others here. Welcome to the forums!
Sorry not a mount it’s the shifting cable bracket
It is a manual trans and when I brought it to the shop to be checked the mechanic was telling me that we needed to replace those parts so I was just wondering where I could find those this has been helpful tho
OK, manual is a different story. I'm not sure how tough it will be to find cables (there are two that go in together) for a 97. For a 91-94; pretty tough. For a 1990, very tough. Sometimes it's just the cable ends that get sloppy, and those can be easier to fix with aftermarket kits. Also the shifter bushings are a notorious source of problems, and there are both OEM and aftermarket parts for those. When you say the "mount" went out, perhaps that's just that the mount is incorporated into the two cables as a unit. Hard to imagine those wear out. If the cables themselves are no longer usable, then you'll need someone who knows 2G series better than I on where to get replacements.
Thank you so much and when I was referring to the mounts I was talking about the shifting cable bracket I just used a grossly wrong word LOL
It says they won't fit mine either for some reason. But clearly they did.
95-99 RS & GS Eclipses use the same shifter cables. You're good to go ahead and order those.
Thank you ywah mine is an rs so I wanted to make sure it would fit before I bought it
If you're referring to the bracket that secures the cable & housings to the trans just before they connect to the levers, JNZ Tuning was able to secure a few and they MIGHT still have one if you contact them ASAP. If not you might be able to find one in a junkyard or from someone who has a spare or eBay. Or maybe even get a metal fabricator to make you one out of metal stock. IIRC it's around 1/4" thick. Someone would just have to give you the right dimensions. I took mine out to derust and paint it while rebuilding my trans, so if you like I can take down the measurements and post them here. Let me know. Btw my trans is a '94 AWD manual.
OP is a FWD 2g, which is different than the AWD 1g.
Not sure how that bracket could've gotten messed up, but it's the same on all the NVT-350 transmissions. Talons, Eclipses, Avengers, and some model Neons will have it.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
