turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Well, i had to cross a part in the road with about 8 inches of standing water in it and although i went as slow as possible to try and avoid sucking up water the next thing i know the motor is dead, it won't even crank over...
SO,, I push it off the road, get a ride home and come back with a truck, tow rope and a spark plug socket.
Sure enough there was TONS of water in my engine, probably at least a half gallon extra in my oil pan, not counting what shot out of the plug wells as i cranked the engine over. I then dropped the IC pipes and got another gallon or more from them.
After getting it started and running again I flushed the motor 3 times with new oil and drained it after running it for a few minutes on each batch of oil.
Since then the J&S knock sensor is picking up a ton of noise anytime i get into it, but there's no audible change in the way the motor sounds. The car is actually idling and running under light load better than it ever has, but now it's making a ton of noise which i know isn't detonation because the way the J&S is displaying it does not match the way it normally acts when detonating... Plus 15 psi on E85 at 11.5:1 shouldn't knock anyway... Then sometimes (once every 5 tries or so) it pulls like normal and only displays 1-2* of timing pull at 30psi (i let the J&S decide when to give the car the last few degrees of timing
Revving in neutral it doesn't make this noise, only when under a load but accelerating hard (1st and 2nd gear mostly) But if i lay into it slowly it can build all the way up and run fine like it use to.
There's no oil in my anti-freeze, there's no more water showing up in my oil or as condensation in the valve cover either.
The only thing i can think of is that when i got it started with the original water soaked oil and revved it up a few times and that maybe i wiped the face off the bearings with those few short revs to 3500 - 4k and now they are making noise. The motor didn't immediately lock, it's just motored down like the spark had died out (which it had)
Any ideas or thoughts on this? If it wouldn't have started only after a hydro-lock, i would swear that the noise is from something else like an accessory pulley or something , but the internals of the engine were the only parts really effected... I doubt the head or block are cracked, and there's no signs of a severely bent rod or anything...I"M STUMPED!!!!!!
Anyone ever hydro-lock one and get it back running again or tear it down to find anything particular wrong besides the few things I've already been keeping an eye on that would cause this kind of noise in the motor
IF no one has any thoughts i think i will put all new rod and main bearings in as soon as I'm caught up on money (2 weeks or so when i collect some bill I've got out to contractors i did work for) but until then i am going to baby the car and try to avoid "racing" anyone or giving anyone a taste of the mitsi out of fear of throwing something out the block
I also NEED new axles, my fronts are so bad that anywhere between 40 - 65MPH the car shakes so hard that you can't even see out the mirrors and everything in the center console and glove box rattles and drives me nuts... I'm just too broke to do anything but wonder now
P.S. Now i wish i would have had the J&S in my last motor that was machined wrong and would eat main bearings every 500 miles, at least that would give me a worn bearing "noise pattern" to look for on the J&S's display.
)Revving in neutral it doesn't make this noise, only when under a load but accelerating hard (1st and 2nd gear mostly) But if i lay into it slowly it can build all the way up and run fine like it use to.
