hy do MBCs bleed off boost
Status
Not open for further replies.
notractiongst
165
Jan 27, 2005
baltimore, Maryland
Im just curious as to why MBCs bleed off excess boost .. wouldnt that be a boost leak pretty much since the MAS has already counted the air ??? i just dont understand why they bleed of boost
What makes you think a typical MBC bleeds off boost?
The usually block the boost from reaching the wastegate actuator until they open.
Once they open the vent may leak some air untill the boost falls off but that's not why it's there. It's intended to vent and trapped air between the valve and the WGA so that the WGA can close once the pressure drops. Otherwise the WGA would stay open after the first time the boost exceeded the MBC setting and you'd never build much boost again. The vent should be tiny and not leak enough air to effect metering.
Steve
oh i was just curious cause it seemed like mine was leaking a whole buttload while i was doing a boost leak test..LOL i forgot to tighten it all the way down
Status
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
