HX40 oiling question
apedog
158
May 6, 2009
Lewisberry, Pennsylvania
This is for an hx40.
So I dont have balance shafts in my car but I ported the oil filter housing so that my pressure would be back to stock. Im running my oil feed for my turbo off of the oil filter housing so will I still need a restrictor? and if so what size?
Every car is differs. Best way is to put a oil pressure gauge between the restrictor and the turbo.... And optimal pressure should be no less than 10 psi at idel and no less then 30 psi at load and max of 70 psi
no one cn answer this for you, you will have to test your pressure and go from there
