HX40 injectors plus E85
^^nope.
I made 550awhp on a 255 intank and a 044 inline with an hx40 (38psi) and BM1550's
Depending on what you tune with I would go as big as you can. Hi z 2150s, I know it's hard to find 1680's the last time I checked.
I have an Hx35/40 hybrid i made fom an H1c and it's the 58mm 8 blade and at 28-30psi i'm running them at 60% IDC, if you want to get a higher flowing HX40 or push most boost on the same one i'd agree with 1600's
Definitely go with larger injectors, and a second pump would be a real good idea. PM me if you'd like some awesome prices on Hi-Z RCI 2200's, or even some 1680's!
I run 1000cc injectors on Q16 with my HX40 at 38 psi...I see 85-86% IDC's...just to give you some perspective on how much injector you would need to make big power on E85.
-Will
