HVAC Lights Not Working.
tsi1991awd
1,366
6
Sep 28, 2008
Puyallup, Washington
I could've sworn they worked before and when I took the console off to install my boost and oil pressure gauges, they weren't working.
NOW, I do know that there is one connector that isn't plugged into anything. There are 2 or 3 plugs on the back of the console itself and there is a skinny rectangular one that is clear/white and it has 2 or 3 wires going to it. I can't find anywhere to plug this in.
I'm willing to bet that's the problem, but there's no space to plug it in, maybe I'm just a dumbass. Anyone know?
Tail lights work fine, all lights work fine (except for those HVAC lights)
Fuse 1 is a 10 amp fuse that feeds the circuit, It goes through the tail light relay and is grounded through the rheostat(Dimmer). According to the diagram i am looking at There is a 2 pin connector , The wire colors are GW and BY For the illumination.
So if the dash light still come on and dim, And you still have tail lights, The problem has to be at the hvac unit, Otherwise something else would'nt work.
Where does that 2 pin connector connect at? I believe this is the problem because I have it disconnected because I couldn't find where it went.
Not to steal the thread but im having same problem.... my dash lights werent working so I cut the dimmer wires and connected both grounds. now the Dash lights work always on ( dont care )... But the HVAC lights dont work... The AC seems to have his light tho.. LOL
Tail lights work , cigarette lighter ring...
only thing that dont work is HVAC and reverse lights
