How to Wire new fans
matt11194
Jun 24, 2011
rossford, Ohio
I have been working on my eclipse and just realized the fans arent turning on. I don't know if it's not getting hot enough to trigger them or if I don't have them hooked up right!
Ya I think I have them wired right but they never turn on. The highest temp itsngotten to is half. It dosent seem to heat up. I think the temp might be off though.
You should have been able to remove the plug off the old fan and wire the new fans up to the plug. that would at least guarantee they are wired properly.
you could always wire them to a toggle switch... but dont use the factory wires if your planning on wiring both with the one wire.. it will burn the wires out..
Is here any way I can directly wire them, my connector is shot?
Just strip 3/4" off ends and wire them together with a wire nut (like in house wiring and electrical tape around it to keep water out). Wire as in my previous link. If you can solder them it's even better.
Or if you'd like them to run whenever the engine is running, use a separate relay like this: http://www.dsmtuners.com/forums/attachment.php?attachmentid=80263&d=1203007364. You can wire both fans in parallel.
