How to tell what settings.....
Im sure thats not how its supposed to look. Sorry about that, but that is the best I can figure out.
what is the 3rd 7th 8th and 9th colum counting from Left to Right.
I see, time, RPM, ??, O2, timing retard, timing, ?,?,?
I think the 8th in injector duty cycle but cant tell.
And is this log all done at WOT?
For us to really be able to diagnose your tune, you'll need to do a WOT log from 2,000 - 7,000rpm in either 2nd or 3rd gear.
From what I can gather from that log, you are running rich between 4,000 & 6,000rpm. 0.98volts is super rich. You should lean it out in those ranges.
From what I can tell:
2nd column is RPM
4th is O2
5th is knock
6th is timing
I think the 3rd is HZ?
being hes on a 50trim, 200hz seems low. I am around 2000 with a BT28. But again I oculd be wrong my car just stated running last night after being down for 8 months so my memory could be off.
Oh, duh...200ish is way too low for HZ. :coy:
2nd = RPM
3rd = gm/sec
4th = O2
5th = knock
6th = timing
7th = intake temp
8th = boost est
9th = hp est
So how is that log looking? I will post a more recent one if I can. Im new to logging and posting. While doing a log I press the capture button moments before WOT and then once thru the gear I press stop, is this the right way to do it. Thanks
