How to tell what settings.....
gsxrtalon
395
Apr 23, 2005
Harrison, Michigan
I recently bought my new GSX and it came with Dsmlink V2 and I have not messed with any settings or anything, the car seems to run good but I have been looking more and more into the link and when I do logs it is not set up to log fuel trims. When I checked the fuel setting they were at 0 across the board .......along with timing. Now does that mean that is what my tune is right now, fuel trims-0 and timing- 0 across the board. Again the car seems to be running good but just wondering how you can tell the previous tune. Thanks in advance.
Fuel settings are changed via the rpm based sliders and they only affect WOT. Timing adjustments are made the same way, but they are in effect all the time. If everything is at 0 then the car is untuned. You need to get access to the dsmlink forums. I suggest reading the manual as well.
yes the timing was at 0 across and the fuel trims were at 0 as well. So this means I have been driving the car with no tune for awhile then. I have done some logs and they dont show any outrageous numbers so I went with it thinking the car had a good tune by the previous owner.
Do you have access to the dsmlink forums? If you don't then you can post a log here.
No the last time time I went to dsmlink.com the registry was closed. I will post a log as soon as I get a drive to load the logs onto my comp from my laptop.
The person that sold you the car should have contacted Tom or Dave to transfer ownership of Dsmlink so you can have access to the forums. Get in contact with the seller and have them transfer ownership.
Is there any way to register new with dsmlink? The previous owner said he bought the car with the dsmlink in it as well and never got the information switched to his name and the original owner can not be found.
E-mail the guys at Dsmlink. If it's a valid version, then they should take care of you.
So wait, even your global fuel & deadtime are set at zero? (lower right hand side on the fuel settings "page")
Technically you can just set these 2 values and never tune the DSMlink ever again and have your car run decently. Not as well as if you fine tune other settings too, but pretty good nonetheless.
Yes, if the car has bigger injectors and you don't know what size they are you will need to find out and write down what the global and dead time settings are. When you are inside DSMLink just hit F6 and that will take you to the fuel box. In the upper right hand side you will see a global number and below that you will see the dead time numbers. The only reason I suggest writing them down is that if you loose power in a 2G, DSMLink will revert back to the default settings, and if those settings are not correct for the injectors that are in the car now, you will have to "hunt and peck" your way back to the base tune you're at now.
As stated, just getting the global and dead time set correctly will give you a decent tune to get around town and do a little boosting too.
Well, like in my profile says, I have 660's. I just checked the fuel page and timing the other day and realized they were set at 0. So there are global and dead time settings for 660's I should set the link at then, right?
http://www.dsmlink.com/downloads.html
Even not being a registered memeber you can still download the newest verison of DSMlink AND the user guide. Pg 16 of the PDF user guide lists APPROXIMATE dead times and Global % for a few various injectors. Reading this guide should get you on your way.
it wont let me open up the pdf file. I thought I had the users guide on my computer already, I guess not.
If you had 660cc injectors and had the global & deadtime values at zero, your car wouldn't run very well, if at all. Are you sure you have 660cc injectors?
Do you have any logs that you can post?
Do you get a error message or anything. I just opened it on my work PC no problem. Do you have Adobe on your PC? Start> Programs>adobe reader (7.0x is the new verison).
How about the .doc file, have office or windows read only "one note" or somthing similar program?
Pg 16 states for DENSO 660s, a global of -31% and a deadtime 180uS is CLOSE values Tehn gives a statement of:
The Dead time area of the Fuel Adjustment dialog is where you can make adjustments
to this dead time figure. The value entered into this area gets added to the value
calculated by the ECU. While there is a way to calculate what this value should be, a
trial and error approach tends to work best. Use the long-term fuel trim (SelectedLTFT)
value calculated by the ECU as your guide. The following outlines a good procedure for
getting the dead time right for your setup.
1. Car must be fully warmed up then must be operated at cruise for about 10 minutes
followed by idle for 5 minutes to get stable LTFT values.
2. Compare the LTFT at idle and cruise. You want both to be right about zero (+/-
5% or so).
3. If the two are about the same, dead time setting is good.
4. If they are equal but non-zero, adjust the global setting.
5. If idle LTFT is more positive than cruise LTFT, increase the dead time, less,
decrease.
On a side note, if the car is running good with 0 on all sliders and 0 on global and deadtime. And by running good, the O2s are in range (maybe a little rich for safety), the car does not buck under WOT and the STFT and LTFT are in check then I would think you do not have 660s. Since when I first got my 580s and dialed them in then reset DSM link I forget to reenter the values and the car would pop and shake at WOT. Took me a second to figure it out. but I was adding ABOUT 28% more fuel that I was suppose to be adding. You just as a base are adding 31% more than is "required" with 660s Not counting the WOT or RPM based fuel settings being at 0. No offense but something sounds fishy. I would defiantly contact Dave or Tom at DSMlink about transffering the ownership and get a account there.
Yeah, if the car is running "ok" at part throttle, and idle then I would sellect LTFTlow & LTFTmid from the Values dialog box and go through the series Spoolup just posted. If the LTFT's are pegged at 12.9%(max readable ecu ltft value) then you know your in need of some major fuel tuning. Matter a fact post a log up in the new "log" section of Dsmtuner so we can help you out! I'll be happy to help you out. I know how frustrating it is trying to get Dsmlink dialed in. :)
I just checked my global fuel and deadtime settings and they were at -32 and 180. The fuel trims and timing were at 0. The car does run fine, the global fuel setting and the deadtime was at -32 and 180 the whole time. I can try to post a log, Im new at posting logs, bare with me. How can I post a log from my desktop saved as a .dat file. Thanks
Can anyone help me post this log, I have exported the log from Dsmlink as a .csv file and then opened it into excel..........now I need assistance to post it. When I attached the file it says invalid upload. Then I just copied and pasted it, and it was really long and not spaced. Any help please.
ps here is the link I was trying to follow to post my log........could anyone assist me a little more. Thanks
http://dsmtuners.com/forums/showthread.php?t=169959
I knew it either had to be that the dead time/global fuel were set or that you didn't really have 660cc injectors. :)
You tried to post the .xls file? This site won't allow a .xls file.
You need to import the .csv file into Excel...Then click on "File" and select "Save as Web Page". That's the file you can upload to this site.
Ok Im still not sure how to do this...........hope this works.
Nope, keeps saying invalid file. I saved my file into excel and saved it as a web page. Then came to the message box, clicked "go advanced" then tried to attach the file. Says, invalid file.........Tried uploading it as a html and a csv. Im confused.
Did you right click the .htm file you created & click "Open in Wordpad"? It will be all code...Grab from the line that says "Head" and copy to the bottom.
Paste into here. Input the following before the stuff you pasted [C O D E] (with no spaces)
And at the end input [/C O D E] (no spaces again).
It may have some space at the top, but that's the best I can do.
Sorry
Code:
<head>
<meta http-equiv=Content-Type content="text/html; charset=windows-1252">
<meta name=ProgId content=Excel.Sheet>
<meta name=Generator content="Microsoft Excel 9">
<link rel=File-List href="./Book1_files/filelist.xml">
<link rel=Edit-Time-Data href="./Book1_files/editdata.mso">
<link rel=OLE-Object-Data href="./Book1_files/oledata.mso">
<!--[if gte mso 9]><xml>
 <o:DocumentProperties>
  <o:Author>User</o:Author>
  <o:LastAuthor>User</o:LastAuthor>
  <o:Created>2006-05-18T15:39:51Z</o:Created>
  <o:LastSaved>2006-05-18T15:40:27Z</o:LastSaved>
  <o:Version>9.2720</o:Version>
 </o:DocumentProperties>
 <o:OfficeDocumentSettings>
  <o:DownloadComponents/>
  <o:LocationOfComponents HRef="file:\\nserv\E\Programs\Applications\MSO2K\msowc.cab"/>
 </o:OfficeDocumentSettings>
</xml><![endif]-->
<style>
<!--table
	{mso-displayed-decimal-separator:"\.";
	mso-displayed-thousand-separator:"\,";}
@page
	{margin:1.0in .75in 1.0in .75in;
	mso-header-margin:.5in;
	mso-footer-margin:.5in;}
tr
	{mso-height-source:auto;}
col
	{mso-width-source:auto;}
br
	{mso-data-placement:same-cell;}
.style0
	{mso-number-format:General;
	text-align:general;
	vertical-align:bottom;
	white-space:nowrap;
	mso-rotate:0;
	mso-background-source:auto;
	mso-pattern:auto;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	text-decoration:none;
	font-family:Arial;
	mso-generic-font-family:auto;
	mso-font-charset:0;
	border:none;
	mso-protection:locked visible;
	mso-style-name:Normal;
	mso-style-id:0;}
td
	{mso-style-parent:style0;
	padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	text-align:general;
	border:none;
	mso-pattern:auto;
	white-space:nowrap;
	mso-rotate:0;}
</style>
 <x:ExcelWorkbook>
  <x:ExcelWorksheets>
   <x:ExcelWorksheet>
    <x:Name>Sheet1</x:Name>
    <x:WorksheetOptions>
     <x:Selected/>
     <x:Panes>
      <x:Pane>
       <x:Number>3</x:Number>
       <x:RangeSelection>A1:I138</x:RangeSelection>
      </x:Pane>
     </x:Panes>
     <x:ProtectContents>False</x:ProtectContents>
     <x:ProtectObjects>False</x:ProtectObjects>
     <x:ProtectScenarios>False</x:ProtectScenarios>
    </x:WorksheetOptions>
   </x:ExcelWorksheet>
   <x:ExcelWorksheet>
    <x:Name>Sheet2</x:Name>
   </x:ExcelWorksheet>
   <x:ExcelWorksheet>
    <x:Name>Sheet3</x:Name>
   </x:ExcelWorksheet>
  </x:ExcelWorksheets>
  <x:WindowHeight>4110</x:WindowHeight>
  <x:WindowWidth>8475</x:WindowWidth>
  <x:WindowTopX>120</x:WindowTopX>
  <x:WindowTopY>45</x:WindowTopY>
  <x:ProtectStructure>False</x:ProtectStructure>
  <x:ProtectWindows>False</x:ProtectWindows>
 </x:ExcelWorkbook>
</xml><![endif]-->
</head>
<body link=blue vlink=purple>
<table x:str border=0 cellpadding=0 cellspacing=0 width=576 style='border-collapse:
 collapse;table-layout:fixed;width:432pt'>
 <col width=64 span=9 style='width:48pt'>
 <tr height=17 style='height:12.75pt'>
  <td height=17 align=right width=64 style='height:12.75pt;width:48pt' x:num>17879000</td>
  <td align=right width=64 style='width:48pt' x:num>3002</td>
  <td align=right width=64 style='width:48pt' x:num>40.1</td>
  <td align=right width=64 style='width:48pt' x:num="00.1">0.1</td>
  <td align=right width=64 style='width:48pt' x:num>0</td>
  <td align=right width=64 style='width:48pt' x:num>27.3</td>
  <td align=right width=64 style='width:48pt' x:num>62</td>
  <td align=right width=64 style='width:48pt' x:num>-8.7</td>
  <td align=right width=64 style='width:48pt' x:num>55.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>17926412</td>
  <td align=right x:num>3041</td>
  <td align=right x:num>41.3</td>
  <td align=right x:num="00.1">0.1</td>
  <td align=right x:num>0</td>
  <td align=right x:num>27.3</td>
  <td align=right x:num>62</td>
  <td align=right x:num>-8.4</td>
  <td align=right x:num>55.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>17974736</td>
  <td align=right x:num>3034</td>
  <td align=right x:num>41.7</td>
  <td align=right x:num="00.12">0.12</td>
  <td align=right x:num>-8.1</td>
  <td align=right x:num>56.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18021260</td>
  <td align=right x:num>3061</td>
  <td align=right x:num>42.5</td>
  <td align=right x:num>-7.9</td>
  <td align=right x:num>57.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18068684</td>
  <td align=right x:num>3099</td>
  <td align=right x:num>42.9</td>
  <td align=right x:num>-8</td>
  <td align=right x:num>59.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18116560</td>
  <td align=right x:num>3117</td>
  <td align=right x:num>43.3</td>
  <td align=right x:num="00.14">0.14</td>
  <td align=right x:num>59.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18163532</td>
  <td align=right x:num>3122</td>
  <td align=right x:num>43.6</td>
  <td align=right x:num="00.18">0.18</td>
  <td align=right x:num>-7.7</td>
  <td align=right x:num>59.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18210956</td>
  <td align=right x:num>3154</td>
  <td align=right x:num>44.4</td>
  <td align=right x:num>0.25</td>
  <td align=right x:num>-7.5</td>
  <td align=right x:num>60.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18258384</td>
  <td align=right x:num>3175</td>
  <td align=right x:num>45</td>
  <td align=right x:num="00.57">0.57</td>
  <td align=right x:num>26.2</td>
  <td align=right x:num>-7.4</td>
  <td align=right x:num>61.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18305804</td>
  <td align=right x:num>3186</td>
  <td align=right x:num>45.1</td>
  <td align=right x:num="00.76">0.76</td>
  <td align=right x:num>61.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18353668</td>
  <td align=right x:num>3238</td>
  <td align=right x:num>46.5</td>
  <td align=right x:num="00.84">0.84</td>
  <td align=right x:num>-7.1</td>
  <td align=right x:num>61</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18400652</td>
  <td align=right x:num>3244</td>
  <td align=right x:num>46.8</td>
  <td align=right x:num="00.86">0.86</td>
  <td align=right x:num>-7</td>
  <td align=right x:num>62.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18448116</td>
  <td align=right x:num>3250</td>
  <td align=right x:num>47.1</td>
  <td align=right x:num>-6.9</td>
  <td align=right x:num>63.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18496012</td>
  <td align=right x:num>3287</td>
  <td align=right x:num>47.8</td>
  <td align=right x:num>-6.8</td>
  <td align=right x:num>64.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18542980</td>
  <td align=right x:num>3310</td>
  <td align=right x:num>48.6</td>
  <td align=right x:num="00.82">0.82</td>
  <td align=right x:num>-6.6</td>
  <td align=right x:num>65.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18590376</td>
  <td align=right x:num>48.8</td>
  <td align=right x:num="00.8">0.8</td>
  <td align=right x:num>-6.5</td>
  <td align=right x:num>66.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18637804</td>
  <td align=right x:num>3345</td>
  <td align=right x:num>50.2</td>
  <td align=right x:num="00.78">0.78</td>
  <td align=right x:num>-6.1</td>
  <td align=right x:num>68.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18685196</td>
  <td align=right x:num>3384</td>
  <td align=right x:num>50.8</td>
  <td align=right x:num="00.67">0.67</td>
  <td align=right x:num>25.1</td>
  <td align=right x:num>69.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18732620</td>
  <td align=right x:num>3391</td>
  <td align=right x:num>52.2</td>
  <td align=right x:num="00.61">0.61</td>
  <td align=right x:num>-5.5</td>
  <td align=right x:num>71.1</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18780044</td>
  <td align=right x:num>3415</td>
  <td align=right x:num>53.2</td>
  <td align=right x:num="00.53">0.53</td>
  <td align=right x:num>24.1</td>
  <td align=right x:num>-5.2</td>
  <td align=right x:num>73.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18827472</td>
  <td align=right x:num>3450</td>
  <td align=right x:num>54</td>
  <td align=right x:num="00.41">0.41</td>
  <td align=right x:num>-5.1</td>
  <td align=right x:num>75.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18874892</td>
  <td align=right x:num>3453</td>
  <td align=right x:num>54.5</td>
  <td align=right x:num="00.31">0.31</td>
  <td align=right x:num>-4.9</td>
  <td align=right x:num>76.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18922316</td>
  <td align=right x:num>3498</td>
  <td align=right x:num>55.9</td>
  <td align=right x:num>-4.6</td>
  <td align=right x:num>76.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>18969740</td>
  <td align=right x:num>3518</td>
  <td align=right x:num>57.3</td>
  <td align=right x:num="00.29">0.29</td>
  <td align=right x:num>-4</td>
  <td align=right x:num>80.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19017164</td>
  <td align=right x:num>3548</td>
  <td align=right x:num>57.8</td>
  <td align=right x:num>23</td>
  <td align=right x:num>80.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19065324</td>
  <td align=right x:num>3575</td>
  <td align=right x:num>58.5</td>
  <td align=right x:num>-3.9</td>
  <td align=right x:num>82.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19112012</td>
  <td align=right x:num>3609</td>
  <td align=right x:num>59.5</td>
  <td align=right x:num>-3.7</td>
  <td align=right x:num>82.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19159436</td>
  <td align=right x:num>3613</td>
  <td align=right x:num>60.7</td>
  <td align=right x:num>-3.2</td>
  <td align=right x:num>84.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19206880</td>
  <td align=right x:num>3637</td>
  <td align=right x:num>61.6</td>
  <td align=right x:num>-3</td>
  <td align=right x:num>87.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19255392</td>
  <td align=right x:num>3702</td>
  <td align=right x:num>63.9</td>
  <td align=right x:num>22</td>
  <td align=right x:num>-2.5</td>
  <td align=right x:num>87.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19301708</td>
  <td align=right x:num>3695</td>
  <td align=right x:num>64.5</td>
  <td align=right x:num="00.92">0.92</td>
  <td align=right x:num>-2.2</td>
  <td align=right x:num>89.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19349132</td>
  <td align=right x:num>3750</td>
  <td align=right x:num>66.6</td>
  <td align=right x:num="00.94">0.94</td>
  <td align=right x:num>-1.7</td>
  <td align=right x:num>91.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19397088</td>
  <td align=right x:num>3754</td>
  <td align=right x:num>67.7</td>
  <td align=right x:num>-1.3</td>
  <td align=right x:num>94.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19443980</td>
  <td align=right x:num>3792</td>
  <td align=right x:num>69.5</td>
  <td align=right x:num="-00.8">-0.8</td>
  <td align=right x:num>95.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19491856</td>
  <td align=right x:num>3827</td>
  <td align=right x:num>71.2</td>
  <td align=right x:num="-00.4">-0.4</td>
  <td align=right x:num>100.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19538828</td>
  <td align=right x:num>3838</td>
  <td align=right x:num>72.6</td>
  <td align=right x:num>21.3</td>
  <td align=right x:num>105.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19586252</td>
  <td align=right x:num>3882</td>
  <td align=right x:num>76.4</td>
  <td align=right x:num="00.7">0.7</td>
  <td align=right x:num>109.1</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19634604</td>
  <td align=right x:num>3918</td>
  <td align=right x:num>79.6</td>
  <td align=right x:num>20.2</td>
  <td align=right x:num>1.1</td>
  <td align=right x:num>113.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19681100</td>
  <td align=right x:num>3947</td>
  <td align=right x:num>82.4</td>
  <td align=right x:num>19.1</td>
  <td align=right x:num>60</td>
  <td align=right x:num>1.6</td>
  <td align=right x:num>119.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19728524</td>
  <td align=right x:num>3964</td>
  <td align=right x:num>86.5</td>
  <td align=right x:num>2.3</td>
  <td align=right x:num>122.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19775948</td>
  <td align=right x:num>4045</td>
  <td align=right x:num>89.9</td>
  <td align=right x:num="00.96">0.96</td>
  <td align=right x:num>18.1</td>
  <td align=right x:num>2.6</td>
  <td align=right x:num>127.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19823372</td>
  <td align=right x:num>4067</td>
  <td align=right x:num>93.7</td>
  <td align=right x:num>16</td>
  <td align=right x:num>3.3</td>
  <td align=right x:num>131</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19870796</td>
  <td align=right x:num>4094</td>
  <td align=right x:num>98.7</td>
  <td align=right x:num>15.3</td>
  <td align=right x:num>4.1</td>
  <td align=right x:num>133.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19918220</td>
  <td align=right x:num>4148</td>
  <td align=right x:num>103.1</td>
  <td align=right x:num>4.7</td>
  <td align=right x:num>137</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>19965644</td>
  <td align=right x:num>4195</td>
  <td align=right x:num>108</td>
  <td align=right x:num>5.4</td>
  <td align=right x:num>143.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20013068</td>
  <td align=right x:num>4204</td>
  <td align=right x:num>112</td>
  <td align=right x:num>13.1</td>
  <td align=right x:num>6.1</td>
  <td align=right x:num>147.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20060492</td>
  <td align=right x:num>4276</td>
  <td align=right x:num>118.8</td>
  <td align=right x:num>7</td>
  <td align=right x:num>156.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20108940</td>
  <td align=right x:num>4315</td>
  <td align=right x:num>123.9</td>
  <td align=right x:num>7.7</td>
  <td align=right x:num>165.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20155344</td>
  <td align=right x:num>4335</td>
  <td align=right x:num>131.3</td>
  <td align=right x:num>12.1</td>
  <td align=right x:num>59</td>
  <td align=right x:num>8.9</td>
  <td align=right x:num>165.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20202768</td>
  <td align=right x:num>4386</td>
  <td align=right x:num>138.7</td>
  <td align=right x:num="00.98">0.98</td>
  <td align=right x:num>11</td>
  <td align=right x:num>10</td>
  <td align=right x:num>182</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20250188</td>
  <td align=right x:num>4475</td>
  <td align=right x:num>147.5</td>
  <td align=right x:num>188.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20297612</td>
  <td align=right x:num>152.2</td>
  <td align=right x:num>11.8</td>
  <td align=right x:num>196.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20346040</td>
  <td align=right x:num>4584</td>
  <td align=right x:num>161.8</td>
  <td align=right x:num>12.8</td>
  <td align=right x:num>206.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20392472</td>
  <td align=right x:num>4641</td>
  <td align=right x:num>171.4</td>
  <td align=right x:num>14.1</td>
  <td align=right x:num>212.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20439884</td>
  <td align=right x:num>4596</td>
  <td align=right x:num>175.5</td>
  <td align=right x:num>58</td>
  <td align=right x:num>15.1</td>
  <td align=right x:num>224.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20488220</td>
  <td align=right x:num>4795</td>
  <td align=right x:num>186.5</td>
  <td align=right x:num>15.6</td>
  <td align=right x:num>237.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20534732</td>
  <td align=right x:num>187.4</td>
  <td align=right x:num>15.8</td>
  <td align=right x:num>247.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20582156</td>
  <td align=right x:num>4845</td>
  <td align=right x:num>191.2</td>
  <td align=right x:num>16.1</td>
  <td align=right x:num>262.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20629580</td>
  <td align=right x:num>4941</td>
  <td align=right x:num>197.5</td>
  <td align=right x:num>16.5</td>
  <td align=right x:num>259.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20677004</td>
  <td align=right x:num>4987</td>
  <td align=right x:num>199.4</td>
  <td align=right x:num>261.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20724440</td>
  <td align=right x:num>5054</td>
  <td align=right x:num>204</td>
  <td align=right x:num>16.8</td>
  <td align=right x:num>272.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20771852</td>
  <td align=right x:num>5165</td>
  <td align=right x:num>210.1</td>
  <td align=right x:num>17</td>
  <td align=right x:num>277.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20819276</td>
  <td align=right x:num>5230</td>
  <td align=right x:num>214.1</td>
  <td align=right x:num>17.2</td>
  <td align=right x:num>289</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20866700</td>
  <td align=right x:num>5312</td>
  <td align=right x:num>218.5</td>
  <td align=right x:num>11.7</td>
  <td align=right x:num>57</td>
  <td align=right x:num>17.4</td>
  <td align=right x:num>298.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20914656</td>
  <td align=right x:num>5245</td>
  <td align=right x:num>216</td>
  <td align=right x:num>311.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>20962288</td>
  <td align=right x:num>5350</td>
  <td align=right x:num>223.1</td>
  <td align=right x:num>17.8</td>
  <td align=right x:num>331.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21009128</td>
  <td align=right x:num>5482</td>
  <td align=right x:num>228.7</td>
  <td align=right x:num>331.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21056400</td>
  <td align=right x:num>5531</td>
  <td align=right x:num>231.4</td>
  <td align=right x:num>17.9</td>
  <td align=right x:num>309.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21103820</td>
  <td align=right x:num>5665</td>
  <td align=right x:num>237.8</td>
  <td align=right x:num>56</td>
  <td align=right x:num>18</td>
  <td align=right x:num>263.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21151428</td>
  <td align=right x:num>5734</td>
  <td align=right x:num>242.9</td>
  <td align=right x:num>18.3</td>
  <td align=right x:num>218.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21198668</td>
  <td align=right x:num>5778</td>
  <td align=right x:num>245.5</td>
  <td align=right x:num>14.2</td>
  <td align=right x:num>18.4</td>
  <td align=right x:num>169.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21246092</td>
  <td align=right x:num>5869</td>
  <td align=right x:num>249</td>
  <td align=right x:num>110</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21293528</td>
  <td align=right x:num>5850</td>
  <td align=right x:num>190.4</td>
  <td align=right x:num>55</td>
  <td align=right x:num>10.7</td>
  <td align=right x:num>56.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21340940</td>
  <td align=right x:num>5760</td>
  <td align=right x:num>77.2</td>
  <td align=right x:num>-8.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21388364</td>
  <td align=right x:num>5622</td>
  <td align=right x:num>29.7</td>
  <td align=right x:num>37.1</td>
  <td align=right x:num>-21.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21435788</td>
  <td align=right x:num>26.4</td>
  <td align=right x:num>36.1</td>
  <td align=right x:num>-22.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21483224</td>
  <td align=right x:num>5639</td>
  <td align=right x:num>16.3</td>
  <td align=right x:num>-25.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21531000</td>
  <td align=right x:num>5580</td>
  <td align=right x:num>14.4</td>
  <td align=right x:num>-25.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21578068</td>
  <td align=right x:num>5556</td>
  <td align=right x:num>10.4</td>
  <td align=right x:num="00.33">0.33</td>
  <td align=right x:num>-26.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21625496</td>
  <td align=right x:num>5396</td>
  <td align=right x:num>-23.2</td>
  <td align=right x:num>54.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21673416</td>
  <td align=right x:num>4980</td>
  <td align=right x:num>60.3</td>
  <td align=right x:num>35.4</td>
  <td align=right x:num>-10.7</td>
  <td align=right x:num>121.1</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21720340</td>
  <td align=right x:num>4300</td>
  <td align=right x:num>83.7</td>
  <td align=right x:num="00.16">0.16</td>
  <td align=right x:num>63</td>
  <td align=right x:num>0.5</td>
  <td align=right x:num>155.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21767776</td>
  <td align=right x:num>3698</td>
  <td align=right x:num="00.37">0.37</td>
  <td align=right x:num>4.3</td>
  <td align=right x:num>169.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21815724</td>
  <td align=right x:num>4116</td>
  <td align=right x:num>100.8</td>
  <td align=right x:num>4.4</td>
  <td align=right x:num>215.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21862612</td>
  <td align=right x:num>4213</td>
  <td align=right x:num>112.8</td>
  <td align=right x:num>6.2</td>
  <td align=right x:num>243.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21910036</td>
  <td align=right x:num>3931</td>
  <td align=right x:num>114.7</td>
  <td align=right x:num>8.1</td>
  <td align=right x:num>244.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>21957464</td>
  <td align=right x:num>4085</td>
  <td align=right x:num>117.7</td>
  <td align=right x:num>7.8</td>
  <td align=right x:num>257.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22004888</td>
  <td align=right x:num>4209</td>
  <td align=right x:num>126.4</td>
  <td align=right x:num>8.7</td>
  <td align=right x:num>255.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22052308</td>
  <td align=right x:num>4024</td>
  <td align=right x:num>126.1</td>
  <td align=right x:num>9.7</td>
  <td align=right x:num>240.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22099732</td>
  <td align=right x:num>4089</td>
  <td align=right x:num>10.3</td>
  <td align=right x:num>241.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22148304</td>
  <td align=right x:num>4218</td>
  <td align=right x:num>139.2</td>
  <td align=right x:num>232.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22194580</td>
  <td align=right x:num>4144</td>
  <td align=right x:num>142.4</td>
  <td align=right x:num>217.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="22242368">22242368</td>
  <td align=right x:num>4185</td>
  <td align=right x:num>145.7</td>
  <td align=right x:num>12.5</td>
  <td align=right x:num>222</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22289428</td>
  <td align=right x:num>4228</td>
  <td align=right x:num>150.1</td>
  <td align=right x:num>7.9</td>
  <td align=right x:num>13</td>
  <td align=right x:num>224.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22336852</td>
  <td align=right x:num>155.5</td>
  <td align=right x:num>8.6</td>
  <td align=right x:num>220.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22384300</td>
  <td align=right x:num>4261</td>
  <td align=right x:num>160.4</td>
  <td align=right x:num>8.2</td>
  <td align=right x:num>14.7</td>
  <td align=right x:num>227.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22431700</td>
  <td align=right x:num>4296</td>
  <td align=right x:num>164.5</td>
  <td align=right x:num>15.2</td>
  <td align=right x:num>238.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22479124</td>
  <td align=right x:num>4257</td>
  <td align=right x:num>167.2</td>
  <td align=right x:num>15.9</td>
  <td align=right x:num>242.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22526552</td>
  <td align=right x:num>4350</td>
  <td align=right x:num>172.9</td>
  <td align=right x:num>252.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22574000</td>
  <td align=right x:num>176</td>
  <td align=right x:num>16.6</td>
  <td align=right x:num>241.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22621396</td>
  <td align=right x:num>4340</td>
  <td align=right x:num>176.8</td>
  <td align=right x:num>17.1</td>
  <td align=right x:num>255.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22668868</td>
  <td align=right x:num>4433</td>
  <td align=right x:num>180.9</td>
  <td align=right x:num>266.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22716256</td>
  <td align=right x:num>4491</td>
  <td align=right x:num>183.9</td>
  <td align=right x:num>264.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22763668</td>
  <td align=right x:num>4448</td>
  <td align=right x:num>186.3</td>
  <td align=right x:num>277.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22811092</td>
  <td align=right x:num>4540</td>
  <td align=right x:num>190.8</td>
  <td align=right x:num>275.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22858844</td>
  <td align=right x:num>4502</td>
  <td align=right x:num>190.9</td>
  <td align=right x:num>299</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22905940</td>
  <td align=right x:num>4573</td>
  <td align=right x:num>197.4</td>
  <td align=right x:num>19</td>
  <td align=right x:num>300.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22953704</td>
  <td align=right x:num>4630</td>
  <td align=right x:num>199.8</td>
  <td align=right x:num>301.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23000792</td>
  <td align=right x:num>4647</td>
  <td align=right x:num>205</td>
  <td align=right x:num>19.7</td>
  <td align=right x:num>302.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23048212</td>
  <td align=right x:num>4688</td>
  <td align=right x:num>206.8</td>
  <td align=right x:num>317.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23095652</td>
  <td align=right x:num>4693</td>
  <td align=right x:num>207.6</td>
  <td align=right x:num>19.8</td>
  <td align=right x:num>314.1</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23143340</td>
  <td align=right x:num>4789</td>
  <td align=right x:num>212.5</td>
  <td align=right x:num>19.9</td>
  <td align=right x:num>315.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23190524</td>
  <td align=right x:num>4759</td>
  <td align=right x:num>210.8</td>
  <td align=right x:num>325.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23237908</td>
  <td align=right x:num>4814</td>
  <td align=right x:num>213.9</td>
  <td align=right x:num="00.4">0.4</td>
  <td align=right x:num>9.6</td>
  <td align=right x:num>20</td>
  <td align=right x:num>329.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23285332</td>
  <td align=right x:num>4839</td>
  <td align=right x:num>217.5</td>
  <td align=right x:num>20.4</td>
  <td align=right x:num>334.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23333576</td>
  <td align=right x:num>4934</td>
  <td align=right x:num>327.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23380180</td>
  <td align=right x:num>4864</td>
  <td align=right x:num>216.8</td>
  <td align=right x:num>20.1</td>
  <td align=right x:num>335</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23427608</td>
  <td align=right x:num>4954</td>
  <td align=right x:num>221.4</td>
  <td align=right x:num>352.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23475028</td>
  <td align=right x:num>222.9</td>
  <td align=right x:num>365</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23522452</td>
  <td align=right x:num>5000</td>
  <td align=right x:num>224.1</td>
  <td align=right x:num>20.3</td>
  <td align=right x:num>361.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23569876</td>
  <td align=right x:num>5040</td>
  <td align=right x:num>227.2</td>
  <td align=right x:num>20.5</td>
  <td align=right x:num>371.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23617304</td>
  <td align=right x:num>5068</td>
  <td align=right x:num>228.1</td>
  <td align=right x:num>397.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23664724</td>
  <td align=right x:num>5109</td>
  <td align=right x:num>229.4</td>
  <td align=right x:num>396.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23712164</td>
  <td align=right x:num>5201</td>
  <td align=right x:num>234.2</td>
  <td align=right x:num>397</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23759864</td>
  <td align=right x:num>5237</td>
  <td align=right x:num>20.7</td>
  <td align=right x:num>405.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23806996</td>
  <td align=right x:num>234.9</td>
  <td align=right x:num>419.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="23854656">23854656</td>
  <td align=right x:num>5282</td>
  <td align=right x:num>239.5</td>
  <td align=right x:num>12.4</td>
  <td align=right x:num>430.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23901844</td>
  <td align=right x:num>245.4</td>
  <td align=right x:num>20.8</td>
  <td align=right x:num>444.1</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23949272</td>
  <td align=right x:num>238.8</td>
  <td align=right x:num>461</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23996692</td>
  <td align=right x:num>5327</td>
  <td align=right x:num>243.3</td>
  <td align=right x:num>20.9</td>
  <td align=right x:num>455.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24044116</td>
  <td align=right x:num>5403</td>
  <td align=right x:num>246.8</td>
  <td align=right x:num>414.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24091552</td>
  <td align=right x:num>5411</td>
  <td align=right x:num>245.8</td>
  <td align=right x:num>400.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24139856</td>
  <td align=right x:num>5459</td>
  <td align=right x:num>246.6</td>
  <td align=right x:num>407.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24186388</td>
  <td align=right x:num>252.7</td>
  <td align=right x:num>378.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="24233856">24233856</td>
  <td align=right x:num>5597</td>
  <td align=right x:num>252.9</td>
  <td align=right x:num>324.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24281356</td>
  <td align=right x:num>221.3</td>
  <td align=right x:num>301.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24328660</td>
  <td align=right x:num>68.8</td>
  <td align=right x:num>-9.7</td>
  <td align=right x:num>278.5</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24376084</td>
  <td align=right x:num>31.4</td>
  <td align=right x:num>34.3</td>
  <td align=right x:num>-20.9</td>
  <td align=right x:num>273.4</td>
 </tr>
 <![if supportMisalignedColumns]>
 <tr height=0 style='display:none'>
  <td width=64 style='width:48pt'></td>
 </tr>
 <![endif]>
</table>
</body>
</html>
[CODE]
