How to replace front turn signal bulbs in 1ga?
leakyfaucet
818
May 29, 2004
cincinnati, Vermont
Hi, I just bought a 91 Talon and it needs a front turn signal bulb replaced. I had a 93 talon before and it was incredibly simple. I checked my Haynes manual but it didn't show how to change them.
It looks like the radiator is in the way. Any advice?
Also, I don't have a boost controller, just have a vacuum line going from the compressor outlet pipe to the wastegate actuator. What is the factory wastegate actuator set at? Thanks!
The clear headlight portion, that sits underneath the pop-up, has 2 screws. You have to take those out and take out the middle "grill" that sits between the lenses. Undo that stuff, pull it away from the side lense and walahh.
If your asking how much boost your running, probably around 10-11.
