How To Replace Dash Switch Bulbs
DogWhistle
Supporting VIP
1,178
762
Sep 13, 2012
St. Paul, Minnesota
We all work hard to make things work and look good on our cars, only to have the smallest things be the hardest to find a solution for. We're tired of burned out dash switch bulbs, with the only solution to be going to a boneyard scavenging for used bulbs from old cars, which may or may not even work when we get them home.
Fortunately for us, there is a bulb available which is an exact replacement, sold by Radio Shack. It does not come in the small base, so this write-up will show you how to solder the bulb in the base.
The first step is to remove the bulb from the switch. A thin, standard blade screwdriver works well. Give the bulb base a twist counterclockwise. Here is the bulb and base removed from the switch.
Next, flip the bulb and base upside down. We used a steel angle bracket with screw holes to hold the bulb securely. While you are at Radio Shack, pick up a roll of solder wick. Heat the two solder points, one at a time, with the soldering iron, pressing the solder wick into the soldered tab in the base. Pull the wick away while the solder is still liquid, and your old bulb wire lead will be free. repeat on the other tab.
When the leads of the old bulb are free from the socket tabs, separate the base, bulb and bulb rubber.
Open the new package of bulbs. These are Radio Shack #7219 Micro Lamp / Part #272-1092. Put the bulb rubber back on and slide the long electrical wire leads through the holes in the bulb base.
Fold the wire leads over each base tab, and solder them together. Do not heat for too long a time and melt the base.
When the solder is set, ship off the extra wire lead.
Reinstall the bulb base into the switch, using a flat blade screwdriver, with a twist clockwise.
Power up the dash lights and enjoy a complete looking dash again! Congratulations!
Thank goodness you posted this!!!! I'm literally in a conundrum because all my headlights and foglights work but the switches don't light up anymore. Can you tell me if these are the same bulbs for a '91 Talon pop-up headlight and a fog light switch? Again, the outside lights work but the instrument cluster switches for them don't illuminate. All factory. Thanks in advance.
If all of your dash lights don’t light up, it may be a bad rheostat (dimmer) switch on the dash, or a blown fuse.
If just certain switches have lights that don’t come on, then you can use the above steps to replace the bulbs.
The article was written for replacing 2G bulbs, but I don’t think that the bulbs in the 1Gs were any different.
Some people are installing led bulbs instead of the incandescent ones shown here. The procedure is the same, but the led bulbs will have a different look: usually whiter.
amazon.com/gp/product/B074WDWSXL/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1&tag=dsm0e-20
Yeah, my dash lights are fine. It's just the pop-up headlight and the foglight switches that don't light up on the dash. Thanks.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
