how to remove crank sprocket?
BLUE89TURBO
31
Nov 18, 2005
cambridge,
Hey guys,
Just wondering how to take off the crank sprocket.
I did get the bolt loose but cant figure out how to remove the sprocket
I bought a 3 prong gear puller but i cant use it for this.
Any ideas on how to remove it?
Thanks,
Jason
The sprocket should come off realativly easily. Somtimes if it dosn't want to come ill gently pry behind it with a screwdriver or somthing.
remove the 4 bolts and the sprocket pops off. if it doesn't, pry on it from behind with screwdriver or tap on it with a mallet. you do not need a pulley puller.
I was talking about the crank sprocket, i used a screw driver and it slid right off.
The job is done and she runs like new again...
Thanks guys
