ECUflash How to read fuel trims in evoscan?
HadesOmega
640
14
Aug 5, 2002
408, California
Ok so I've got the Open Port 2.0 cable and ECUflash and I'd like to tune my fuel trims with some new injectors I want to install. Before I was tuning with the SAFC and I got it dialed in pretty well with the pocketlogger. So now I want to use evoscan but its different than the pocketlogger for LTFT and STFT. On the pocketloger it would be +2, -5, +15, etc.... But with evoscan I am getting numbers like 99.500, 100.345, 104.345, 95.323, etc...
I'm used to the pocketlogger readings where I'd just add the 2 numbers together and it would tell me if I should add or subtract fuel. Is there someway I can make evoscan work like that?
Here are some picture of what I'm talking about:
Logging > Edit Data Item List > Eval:
Then change (0.1953125*x)-25 to read (0.1953125*x)-125.
Kewl deal, thanx delta448 I will try it out when I have the time to play with it. I knew there was some kind of conversion but couldn't figure out how to change it.
