ECUflash EvoScan Does Fuel Trims values are incorrect ????
dawid4444
233
Feb 16, 2009
Chicago, Illinois
hey guys
i found a good thread on 3si forum about evoscan
How to: Tune Scaling and Latency tables for larger fuel injectors using ECUFlash
i started reading this and post #2 and #3 says that evoscan values for fuel trims are incorrect ?
is this true ?? Does someone heard about it before ??
should i change the values ? or just leave it how it is ?
im asking because im going to put 1000cc in my car tomorrow and ill be using ecuflash to flash it and evoscan to dataloging
thank you guys :hellyeah:
hey guys
I dont think so, I mean even when I had my 450cc's my fuel trims were all within the %5 range. my FIC 950's were a little tricky because I only adjusted 11.72v and 14.06 but if I probably wouldn't operate the car with lower voltages anyways.
yeah I am sure, if that wasn't the case then alot of new people using evoscan would have a really rough time getting there injectors dialed in.
