Are these fuel trims right?
92tsifwd
572
Feb 1, 2004
Hastings, Nebraska
ftrl 87.5%
ftrm 100%
ftrmh 100%
I have tuned for no knock but am getting really low 02s.
02r ranges between .20v and .87 through the curve
02f 2.18v all the time.
I have tuned and am getting no knock but my 02s are still low. why? I thought the perfect fuel trim was 100%
So would 87% be lean? I was getting 45 deg of timing peak timng. I am new to datalogging so some help I would apriciate. I can post more info if needed.
Ok, why are my 02s low then? espeshaly at low rpms like .20s? Bad o2 sencor? What is a good way to know if you are rich or lean at idle when trying to tune? Should I worry about the low o2s cause I am not getting any knock?
i usually tune 1g's for no knock as long as you knock sensor is working. I dont usually trust narrow o2's for tuning.
I use the narrow band output off my PLX-M300 and my fuel trims are low also, but my Wideband says everything is good, so I just don't worry about it. As long as you are in the 70s you will be o.k., you might want to try to lean it out just a bit though if you can.
Good luck.
