General How to program STMPRO ECU to use Mitsubishi IAC
northernwrenches
Jan 28, 2026
KASILOF, Alaska
I have a 1992 Mitsubishi Mighty Max with a 6G72 in it. I have install a STMPRO ECU in it. I am trying to figure out how to program the ECU to use my factory IAC valve. It is a 6 wire IAC. The two red wires are the positive side of 4 coils each controlled from the low side. The ECU is using tuner studios. Has anyone had any luck doing this?
  • Wanted PASSENGER DOOR LOWER MOLDING
    WANTED
    • LA_gst
  • For sale 2g 2g 1999 eclipse gs-t spyder
    Very clean 2g spyder, only modifications is 14b turbo with 3inch exhaust. Well maintained and...
    • DSM B
  • For sale 2g 1996 Talon TSI AWD
    1996 Talon TSI AWD $10,500- 90,421 miles ( will go up a little ) - clean title in hand -...
  • For sale 2g 2g power window motors. OEM
    RH and LH power window motors. OEM $40 each or $70 for the pair. Message 702-741-6987.
  • Wanted WTB 268 Camshafts & Zero Tick Lifters
    Looking to see if anyone has a set of 268 cams in drop-in condition. I know 268 is on the Rare...
    • Ice9
