How to make the A/C fan turn on?
alice
309
Sep 7, 2006
Canandaigua, New York
I have both stock fans still wired up in exactly the stock form. I have also removed my a/c. However, only my passengers side fan comes on not the a/c fan. How do I get the a/c fan to turn on at the same time as the passenger fan?
i see you have dsmlink. i don't have any experience hands on with it, but maybe there is a setting to use the a/c fan as well since both fan relays are controlled by the ecu. if there isn't you could just rewire the a/c fan relays to be triggered by the radiator fan output. i don't think you can run both fans off the radiator relay circuit though.
If I just leave the a/c button depressed the a/c fan will turn on? Also, with DSMlink I can turn both fans on but they are always on until I shut the car off.
