how to install safc?
Alot of links on 2gnt page, not sure if any of them will work for a 96....i know there are little differences between all of the ecu's for our cars....
Sorry i cant help :confused:
I'm going off memory here. I have a 97, but I think the 96 is the same.
TPS wire - Brown with Red
MAP wire - Yellow with Black
A/F wire - White with Black
RPM - I think its solid white on the bottom harness
Power and ground you should be able to find if your doing this yourself :thumb:
Hope this helps. I'm pretty sure I'm right, but double check with a Chiltons Guide or something. The only one I'm a little unsure about is the TPS
