2G How to install Bobbys billet ARB brackets
So this write up is pretty basic really.
When you open the box please open it on a table incase you open it upside down and drop them.
The rear ones are easy and use the same length bolts,
Fronts use 2 different length bolts and they are placed in the holes assigned to that bolt from the box.
If it does fall out the upper bolt is the 25mm bolt and the lower bolt is 30mm long.
Other then that its a basic bracket swap. you can add some anti seize paste as good measures and practice on the threads.
