How To: DSM Throttle Body shaft seal install. The easy, fast and accurate way everytime.
Wanted to share this video as I have always used this method and while rebuilding a few Throttle bodies it was a good time to show its simplicity and effectiveness.
All it requires is M10 studding. 2 washers, 1 nyloc nut and 1 non locking nut! Thats it!!! Its a perfect tool and self levels every time perfectly
Nice video Bobby. It goes to show that "there's more than one way to skin a cat" as we put it. :thumb:
Could one use a M8 allthread so you don't worry about tearing a seal? Wouldn't it still pull the seals in "straight'?
Either way, very good information sir! :applause:
Yes M8 could also work as once the washers have loaded up they are then straight also. Its not a huge issue with M10 wont rip if your careful but any size would be safe to use so M6 even with larger OD washers
I figured you would say just what you did. Thanks for all you do! Super helpful! :thumb:
