How much power on 9psi with B16G?
TurboGeoff
247
Dec 6, 2003
Redwood City, California
Im runnnig wastegate pressure (9 psi) on my Big 16g. Simply because iam on stock fuel system except SAFC2. The car is relatively slow compared to others i have owned. How fast should it be and how much more can i turn it up on stock fuel?
-Geoff
9 psi? Are you dead serious? Thats lower then stock, put it up to atleast 13. Mine is currently at 15 w/ a 16g and all i have is a re-wired pump.
Ohh ok, ya im still pretty new with these cars and im taking my time, but I guess ill bump her up to 13 with my MBC tomorrow.
So, im assuming 9 psi on a big 16g is still pretty damn slow even though its a bigger turbo.
just understand that getting a bigger turbo does not just make the car faster. Sometimes it can even make it slower if the supporting mods are not there. On a 1g you should be able to get the psi up to 13-14 before fuel cut becomes a problem. Just remember that the turbo is only one factor for the cars speed. Its a package deal. if you have a 16g with all supporting mods you will be faster then someone with a 50 trim without the right support.
