How much boost should I be pushing with this setup...?
EclipseGSX_53o
Mar 6, 2011
redding, California
First off, I've done all the free mods and all neccesary maintenance needed.
Here are all the upgrades I've done.
Walboro 190lph fuel pump (rewired)
Dejon intake with k&n filter
2.5 inch exhaust piping to aftermarket muffler
Auto meter boost gauge
Greddy profec b spec ii boost controller
Dodge mod 1g BOV
Besides all that everything is stock.
So, how much boost will be safe without to much knock??
Without a having a wideband to watch afr's or having a logger to see what's actually going on it's hard to say when you will see knock, to be safe just keep it at 15psi or less
Sent from my iPhone using Tapatalk
Gounare stuck at stock boost levels until you get larger injectors, a tuner, and a logger at the least. You would be wise to get a wideband too as was mentioned so you accurately know your AFRs when tuning.
^^^I wouldnt recommend pushing it above 15psi, let alone pushing the stock ecu parameters to higher load values without being able to adjust ign. timing. Also there isnt that much headroom for those stock injectors anyways.
***budget build recommendation: evo 8 injectors with evo 8 ecu w/ecuflash...
