How much boost for this setup?
Shamrokk
82
Jan 24, 2011
Hattiesburg, Mississippi
Im running a 92 gsx. Current mods are mbc, 3in downpipe, test pipe, and exhaust, and a 2g maf and hard pipe. Im about to add in rc 550 injectors. I do not have any way to tune yet. How much boost can be ran on this setup?
Using stock 14b turbo
Idc means injector duty cycle. Rule of thumb is you want to run your idc's to no more than 80% to keep you in the safe zone. All i can get out of them is 14psi on frank 3 20G. If your coming to pick them up from me today best way to get to me is taking HWY98 to HWY57
Go ahead and get Ecmlink, ive had it for a short time and it much much better than the piggy back setup i had. The learning curve isn't to bad either cause all the help from others here.
If your running a 14b i don't see why not. As stated above you'll need a logger of some sort to get the most out of them.
15psi LOL. Add boost till u knock or untill u max out the turbo on the dyno you will see it fall on its face fast. Save up for 16g if you wanna go above stock boost lvls.
I learned from my tuner this summer that Lucas/RC injectors are rated at 50psi of fuel pressure. What that means is in order for them to flow 550cc or whatever number they're rated, you need to bump up the base fuel pressure or use a non-turbo pressure regulator. At stock 1G fuel pressures RC550's wouldn't be much more potent than the stock injectors...so you could potentially run super-lean and cause a serious problem without a wideband and a way to long/tune.
Wait and do the job right. :thumb:
I'm boosting 22 lbs on stock internals on a 2g and i haven't had a problem
With a T25....a turbo that is out of it's efficiency range at anything over stock boost levels. Unless you have a super-efficient intercooler, all you're doing is overheating the air charge and prematurely killing the turbo.
