How long does your battery last without starting the engine?
1997 Eclipse
107
Feb 3, 2003
Manila, Asia
I was just wondering with other out there. How long does you battery last with enough charge to start the car, if you don't use the car. I generally on use my car on Friday nights or during saturdays. By the following weekend the battery has run down to less than 11 volts and I need to charge the battery. Anyone in the same situation?
2 weeks should be ok I think.
One time I was on vacation for 13 days. The car just sat at the airport for that time.
It started ok when I got back. But, at that point, the battery felt like if I have to crank more than 6 or 7 times, it is going to die. Lucky for me, it started at the first crank.
May be you've got a leak somewhere in the car. I'm also a newbie. So :confused:
My mechanic won't touch anything electrical. They said I need automotive electrician. :confused:
Hope that helps
Clarify if you have a stock battery or a 'high performance' one.
I don't know much about batteries, but like you I only drive my car on weekends, sometimes every other weekend. I have an Optima Red Top battery, and the longest I've gone without driving it was for 19 days, and the car started just fine.
Hope this helps.
I have a Diehard battery. How much is the Optima Red top?
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
