How is your AVC-R installed?
Lordpaxin
1,890
15
Apr 21, 2003
Jackson County, West Virginia
How do you have the AVCR vac lines installed. I dunno if mine is right.
thanks.
How do you have it? I think you tap the line that has the BOV and the intake on it (for boost source) then the turbo to WGA line. Thats how it is on the Profec B AFAIK.
I have the solenoid hooked up like this
one line goes to the MAF, and the other goes down and t's for the actuator and outlet pipe.
is this right? or does the line from the solenoid run directly to the acutator
i have boost set at 1.2 bar with 44% duty
it slamms to 10 psi, then creeps to 18.
makes me wonder if its working right, shouldnt it just go right up to top boost.
