avc-r
XhcXkid
Jun 2, 2004
omaha, Nebraska
I have huge problems keeping my boost under controll sinc eI switched to a 16g from a 13g
can some one please help me with setting up and avc-r
I hate hitting fuel cut
did you get a flapper installed on the turbo at all? messing with the avc-r may fix it but a flapper on the turbo would help also.
a flapper
excuse my ignorance but what are you talking about
the 16g is one of the creepinist turbos they make.
what is your 02 housing situation?
with my avcr, i set the boost desired to 1.05 bar.
thats around 17 psi.
and then adjusted the s0olenoid duty cycle up until it would hit and stick.
i still creep past 5k rpm a few psi.
reset your avcr to factory settings, and start new,
mine doesn't hit and stick and presently my boost read is way off, which sucks
so just initialize and restart...ok
I have the buschur Big as #### O2 housing for internal wastegates
also, when i first installed mine, i had the lines off the solenoid running wrong, and boost was very erratic.
infrom the turbo outlet pipe nipple, and out to the wastage, 2 lines no more
thank you, you;ve been very helpfull
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
