How far with my 14b?
Race94
1,151
Jan 6, 2003
Puerto Rico
Well my car currently has 3" turbo-back, UICP w/1g BOV, 190lph and boost control @ 15psi
My question is what will be the best time i'll get out of it?
Also what would be next inyectors or clutch?
Thanks
Thanks
With a stock suspension you will stay around the 14.8-15.4 range. You might go lower or higher, but that is what you will see with minimal mods as you have and NO suspension. Depending on many many things.
You need a clutch to put down any power. The injectors will help, but are useless if you can't put that new found power to the ground.
After a clutch I would atleast buy some suspension parts. It will help you more than you know.:thumb:
My Galant went 12.79 on race gas with a 14B, 2G MAS, 3" Exhaust, 560's, ACT 2600, and 167,000 miles on the suspension. If I had a good suspension I could've gone a little quicker. I'd say mid to high 14's at best since you aren't gonna get any traction with FWD. I'd say do a clutch but with FWD I don't know if your gonna put the power to the ground anyway, maybe injectors would be the way to go.
John
Originally posted by atc250r
My Galant went 12.79 on race gas with a 14B, 2G MAS, 3" Exhaust, 560's, ACT 2600, and 167,000 miles on the suspension. If I had a good suspension I could've gone a little quicker. I'd bet you could get a 13.9 out of it if it's AWD. Definitely do a clutch next.
John
Yes, if he was AWD I would have given him the benifet of the doubt (13.9-14.5). He is a 2G with FWD and has very limited mods on his car to run much better than what I stated. You have MANY things over him......AWD, better stock suspension, clutch, Injectors, Racegas, and I am guesing you didn't run 15psi.
As for the clutch, yes, he needs it very badly.:thumb:
I am not flaming you or saying you are wrong, just keeping him level headed about his where-a-bouts so far in his setup.
besides gettin a clutch what are the best suspension mods? i dont mean to cut in but i have a 1.25 " drop with tokico shocks think ill run decently?? i dont have my clutch yet so i still have a lot of traction issues..o and my mods are the same as his pretty much and im runnin 15 psi as well 17" tires z rated if that helps
You could get around the 14.xx range. Depends on you driving now. You could use the clutch and injectors to get a better time/mph.
Sounds like you are good enough in the suspension territory. Keep it up.
forgot about suspension, i got tokico in the front/KYB GR-2 in the back w/sportlines, i got cheap tires tough :(
Best i have done is 15.3@93 without the turbo-back, this was doing 2.7 on 60ft
So clutch would be next after some good tires?
