14b internal wastegate, how far does it open
DroppedMitsu
85
Jan 24, 2008
Vacaville, California
I did a search for multiple terms so sorry if theres a post on this somewhere. Anyways, I am putting a 4g63 into my truck and had to re-clock the turbo. Well I forgot to see how far the stock wastegate acuator opened up the stock internal wastegate in a 14b, and i already cut the actuator's rod so I can't go back and check. So can anyone tell me how far the stock wastegate opens with the stock actuator, all the way, 3/4, or what? Thanks for the help.
thanks, I know the more it opens the better so I don't have the boost keep building. anyone else with a definite answer of how far it opens would be appreciated even more.
About 3/8". Yep, that's all.
Fully open:
Believe it or not, the size of the hole itself has more of an effect on wastegate function than how far the flapper opens.
Thanks for the help and info/picture. Didn't know that about the hole and flapper size, great to know though thank you.
Opens about 3/8 as Justin said. Std you need to pull the actuator arm 1/2 a hole to get
the arm onto the pin. If you make the arm a full hole short for preload, it won't hurt it ;)
Cheers !
