Jdevil187
- 127
- 14
- Aug 3, 2014
Houston,
Texas
At the moment I'm shifting with a shift box, but I hate holding the damn thing. My tcu is fried so its been completely deleted, what options do I have other than the shift box?
Shift buttons wired to shift box thru the clock spring for the airbag\horn
are you using a ratchet shifter?I run the manumatic setup and shift with the shifter. I like it and it's simple.
Forced Four Shift Box Lite. You have to use the buttons, the lite version doesn't come with a hand held unit. I plan on upgrading to the version where u can use buttons and\or program shift points.
forcedfour.com
I'm currently using the plus, and I don't believe is possible to program it to shift for you
Not sure on the shift box wiring, but as far as the shifter goes, just hook the cable to it and shift. I would have to assume that the box will need wired to the shift soloniods in the transmission. That's easy enough. It will probably need a rpm signal from the ecu and an overdrive switch.
Is the wiring still in place for the tcu? If so, you should be able to use it for your shift box.my tcu is completely deleted. I'm thinking It my work on the stock shifter.
