how do you seperate turbo from turbine housing
Four62ci
Apr 5, 2005
Clearfield, Utah
Can anyone tell me how to seperate a 16g turbo from the turbine housing. I looked in the manual and it doen't tell how to disassemble the turbo.
look near the banjo bolt.. there should be a v-band clamp with a 10mm bolt. undo the bolt and gently remove the turbine housing.
when reinstalling, there is a "pin" you need to line up. make sure that goes in the hole and the v-band is secure before reinstalling.
