TSiInTX
- 0
- Oct 30, 2004
san antonio,
Texas
i got a a/f guage, what wire do i tap? what color anyway, on my honda it was the blue one, what about this one? its a 95 eagle talon TSi
flyboy346205 said:Ok so what wideband would you recomend?
, but i have the same gauge im installing today and i need to know if the 02 is working properly.jackstandracer said:I dont care for the light show gives my girl something to look at, but i have the same gauge im installing today and i need to know if the 02 is working properly.
jackstandracer said:i just looked at my ecu connectors and you guys say that the digram is for 1g's? well in that picture theres 4 sets of connectors 1g's have 3 so wtf?
Interesting comment!Quasimondo said:Better off just sticking it in there and leaving it umplugged if you want to fill the holes, imo.
he is right! but here is the direct linkplayitlouddsm said:Vfaq is your friend. http://www.vfaq.com/index-main.html or http://www.vfaq.com/index-main.html i believe your looking for pin # 4 to tap into.
You are welcome. and don't worry about it.92talonfwdtsi said:^^^^^^^^thanks alot,,i tried searching beleive me
SpoolinTalon2 said:i was talking about the wiring, but these instructions help. i already have the gauge hooked up to the light dimmer switch so all i would need to do is hook up the o2 sensor wire, but now that i think about it, im gonna need constant power to the gauge or else i wont be able to see what the gauge is reading, but from reading on the instructions you provided, i dont know if i will be even able to see it due to sunlight. so what do you guys think: should i just leave the gauge hooked up to the dimemr switch or should i give it constant power and hook it up to the ecu like in the instructions above? thanks again
SpoolinTalon2 said:alright sounds like im going with the constant power from the ecu. thanks guys.
