2G How do I install digital gauges?
You can do it, and there are many options out on the market. You just need to figure out which ones you want, and hook them up. Many should come with their own analog to digital converters, but I'm sure not all do.
dakota digital does custom gauges but they are f***in expensive.
you might wanna look into something like THIS
pretty much anything is possible if you have enough money
Actually pretty easy to do if youre good at cutting plastic and splicing wires...
Not a dsm but i get compliments all the time.
And herr was the tach test
nice. is that on a honda cluster?
Wow, any links never seen that before+ my tach stopped working so this is a good option
Its easy.. you just tap power, ground and tach signal and good to go.. i could walk you through it. Hardest part is hollowing out room
Intellitronix is good stuff. I'm running their oil pressure gauge. It's super accurate, and looks great. I custom mounted mine in the cluster. As others have said, the hardest part is cutting/modifying the cluster so it doesn't look like crap in the end.
My advice here would be measure twice, cut once.
Crappy night pic...It looks awesome in person.
Well hello!!!
I don't remember seeing that in your build thread.
Looks immaculate!!!
Gst the one you're using is defenetly the one I prefer.
However I haven't seen that one sold separately for the tach.
Well hello!!!
Looks immaculate!!!
You can take the electronics out of the housing for a flush look if you wanted.
  • Wanted 6 bolt NT water pipe
    • chrisman287
