How do i fix a loose wire?
97spyder maayng
71
Sep 11, 2004
toronto,
So i was adjusting my tps sensor (1g) and stupidly i knocked out a wire that goes into the CONNECTOR.
No clue how these connectors are assembled, is it possible to somehow get the wire back in there or do i just need to find a pigtail to solder into? If able to fix, what do i need to do/get?
If the pin/terminal came out with, you will have to look closely to see if it's locking tabs aren't bent or missing and try reinserting if ok/fixed. If the pin/terminal is still in the connector you will have to remove it and solder the wire to it (or new one if necessary). This may help (if you have that type of connector): http://www.dsmtuners.com/forums/showthread.php?t=170393
Wow thanks alot guys, that link made it much easier to understand what's going on in the connector. :thumb:
Im going to the auto wreckers today to pick up a hood prop,but ill pick up a pigtail too just in case.
THANK YOU
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
