Holset Question.
Eeeeky
344
4
Oct 8, 2008
Roosevelt, Utah
Hey guys, i have my H1C all mounted up, and nearly ready to go. What i am lacking is a Vband clamp, and flange / down pipe for the turbo. Where might a guy get these two things? I have searched and searched to no avail.
Where to go?
Thanks!
Aeryk
Noone?? Gotta be a good source out there
How big of V-Band flange do you need for downpipe? Downpipe will be custom with a V-band flange, clamp should come with the flange. if your looking for a v band flange from 2.5 to 4" try suprasport.com. they have v-band flanges and clamps. as far as the down pipe, find an exhaust shop in your area with a mandrel bender. a regular tube bend will work, but madrel bends make sure there are no kinks or ripples to slow exhaust flow. hopes this helps
i believe its a 3" outlet, however, noone around here has a mandrel bender, and its going to have to be a hell of a bend. Im thinking ill be making my own if i get the clamp. my biggest problem is the clamp, i can make the flange.
