dsm-onster
DSM Wiseman
- 8,592
- 131
- Jul 11, 2004
Bloxom,
Virginia
That would put you at about 3800rpms with the .63 a/r housing with the gt2871r. Some 4g63 guys report that spool speed with the fp3052 which is a gt30r with the large a/r fp turbine housing. Your cams could be a bit more aggressive than the typical 272-style upgrade cams to which us dsm guys are accustomed. Or your longblock could have less VE at spool rpms than the 4g63.
I had to use a chisel too. And a prybar as a chisel. The only advice is not to do too much on one side. A turbo has very close tolerances and you can have the turbine housing bind against the turbine wheel and bend/chip a blade or bend the shaft if you pry it off crooked.
I have the compressor off and would like some advice on removing and clocking the turbine housing? I have seen people saying it can be a pain. Using PB blaster, rubber mallet, and even a chisel. Any suggestions will be appreciated.
. I always like to see someones direct comparison impression of any turbo. Afterall in the end, we do all this work for how it feels.
I need something to swap to after I max out the big h1c.
