holset housing and setup
dsm4life91tsi
47
Dec 17, 2010
So Sioux City, Nebraska
Ok ive had my holset hx35 for a few weeks now and iam trying to find the housing for it, (bullseye housing)? and iam also need help on what eshaust manifold to run, ive got supporting mods as well
I take it you haven't read any of the Holset threads have you? The stock housing is hands down the best being twin scroll but will require more to get it set up. There is also the T3 housing And the bolt on housing.
Being on a 420a I personally am unsure if you can find a manifold for your head that uses the standard dsm hole for the outlet. Best bet for you would be the t3 housing.
http://www.dsmtuners.com/forums/turbo-system-tech/371627-holset-turbos-part-8-a.html
If you're looking for a bolt-on turbine housing then, yes the Bullseye housing is what you're looking for. You can find the BEP housing a couple places. I know S&R Performance has them off the top of my head.
I'm confused, you have 420A in the title and then used the 1G logo on the thread. What car and engine is this for?
edit: most likely a site glitch that is translating the 1G icon into the word 420A and putting it at the top of the page in the navigation tree.
In that case the other information is correct and I think the cast T3 manifold that was mentioned is the ERL manifold.
Thanks wes, I cannot believe I didnt take notice to the conflicting information and if yo do happen to have a 4g63 and plan on going with the t3 manifold it is the ERL that I would recommend. For the bolt on housing many use the forced performance manifold, including myself.
  • Wanted 6 bolt NT water pipe
    • chrisman287
