holset housing
He is not looking for a bolt on housing. He was looking for the T-3 housing. You did give him the correct link though.
theturbotrader should be able to hook you up. Here is a link to the housing you need.
The Turbo Trader
I think the hx35 is a better choice for my new setup but I can’t decide which housing to run. I want to use my punishment-racing t3 with 44mm waste. Hers my new set:
AEM EMS
Ported 6 bolt cylinder head
Manley 1mm over valve
Crower spring with titanium retainer
Supertech Reduced OD Valve Stem Seals
Ferrea copper/bronze guides
HKS cam 272/272
6 bolt bottom end
Eagle H-beam rod
ACL Race Series Main and Rod Bearings
Tial 44mm wastegate
Don’t know what kind of piston to run. Maybe Wiseco 8.3:1 or the 1400hd. It will be my dd. I want to run water/methanol but in the future.
Have a housing made for you!!! I just did. It seams to work very well. I am running a hx 35 and I had a old t3 garett housing machined for the holset. Set me back a whole 100 bucks and bolts into my exhaust. Only took the guy 1 hour to make too!!
I got my HX35 today but is it real?
it says its made in the USA:confused:. i thought holset was from UK:hmm: hopefully its real:pray:
How much power do those hx35s make. I have a hrc super 16g and it flows like crap, buddy that i bought the car from put it on. From my understanding is that it uses a T3 flange and it looks like my manifold has an adapter for the t3 flange. Could i theoretically put a holset on there instead?
really? are you sure about this? On turbo trader's site it has an option for the housing to be in hx-35/hx-40 and doesnt make you choose one or the other, this makes me think they are the same.
