HKS boost gauge help
Syndicate
130
Jan 22, 2004
Apopka, Florida
I have a 60mm boost gauge -2.5b- that is a peak/warning . Its a newer style *right before when the numerics looked slightly cursive ) ( late 90's ) But it was before HKS had a place in USA so no data here can be found on it . I did find out the extra wires are optional ( there are blue / purple / brown wires out of the harness .. for fuel inj pulse / air etc )
Anyway I installed it and the wires are red orange yellow black , 12v , 12v switch , lights , ground . I used radio fuse for the 12v switch , the old line i had rigged to the light switch , 12v constant I am using a "unmarked" fused spot which lit up the pen light when i tested it , and a good working ground .
Im using my line for pressure from the fpr/mani , This is what happens . At first I turned on the car and the red light on the gauge ( which can also turn yellow ) went on and the needle was pegged past 2.5 . It lit up with I hit the lights etc , Anyway I couldnt figure out exactly why it was pegged . I pressed the select button and it had the green and red light on , I pressed it again and the needle dropped to what we would call -25 vac and the red light turned yellow . I pressed the reset button , I pressed select again and pressed reset and it did 2 sweeps then pegged red again ( when the green and red lights are on ) On the RED only light it reset did nothing also.
Well I couldnt figure out what was going on , so I pulled the 12v constant and no led lights this time . I put the fuse back in and now its pegged again and the red light is just blinking .
( in all modes , the needle was not moving under boost ) I am open to any ideas or suggestion . Ill ###### just ebay if I cant get it figured out tonight. The gauge is also like new so i doubt its malfunctioning.
just lil update on testing , if i unplug the solenoid the GREEN/RED leds that come on , only the green stays on ( alough its still pegged ) I dunno why it was blinking red but I turned the fuse around again and it doesnt do it.
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
