hks 272 questions
TSITurbo95
18
Oct 26, 2009
Ohio, Ohio
so I installed HKS 272's today, and my vacuum is at 12-13hg at 850-900 rpm's, is this normal for these cams with stock cam gears (if that matters?) Also how much "lope" should I have? Should it be noticeable? My lope now is quite noticeable, but some say it does not lope, and others say it does. Which is the truth?
Yeah just took it for a drive, and love how it pulls, and love the aggressive sound!
As has been mentioned in this thread vaccuum is normal for these cams and yes its normal for them to lope. If you get a chance read post 51 of my cam test thread and it will explain a couple things you need to know about bigger cams and turbocharged cars and more so what direction to start in as far as tuning goes;) http://www.dsmtuners.com/forums/cyl...est-delta-hks-272-delta-k272-bc-272-cams.html .
my car is ripped apart as we speak HKS 272's are in as well cant wait to start it although im very nervous to start it i just have those negative thoughts of my timing being off or something sounds really good i like it
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
