High Timing and High Phantom Knock
Aphix
320
Aug 14, 2008
Salina, Kansas
I finally got my OP2.0 cable and ecuflash setup going, started to log on evoscan and found myself with high counts of knock.
>8 at idle, and upwards of 50 at erratic spikes while driving. I know it has to be phantom knock as the car wouldnt be moving if that was really the case. So I assumed my timing was getting pulled real bad and came to find out that timing in most cases was acting fairly normal (I think?), anyways I made a log of a 2 to 3 pull from about 30 to 70 to show somebody that might have seen this or could shed some light on it.
Car is running 16g @ 10 psi currently on the stock fuel system.
I attached a screen shot of the 2 to 3 pull with rpm, knock sum, and timing showing; along with the actual log file.
