High Oil Pressure
triggerx
364
10
Aug 15, 2009
Gilbert, Arizona
So my talon runs with fairly high oil pressure all the time.
Well Under Idle conditions everything is fine, and the pressure seems like it is where it should be.
But when Im driving the pressure goes up considerably.
I run a 20w/50 synthetic blend in my car, after doing some research I guess that this is bad in itself.
But is that really my problem?
Define high? Idle should be about 18-20 psi and driving should take it up to 70-90 depending on rpm. But you should be running some 5 or 10 weight. I run 10w30 in the winter and 40 in the summer
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
