Lambiablo
- 90
- 5
- Apr 8, 2008
Elon,
North Carolina
Hey Guys,
I have a 6 bolt I recently built (approximately 1200 miles or so on the new build). The engine is bored 20 over (wiesco pistons on eagle rods), new front cover, eliminated balance shafts etc. I began seeing some oil on the ribbed side of the timing belt and cam gears as soon as I began getting into a little boost, which was around 500 miles of break in driving.
I know that eliminating the balance shafts increases base oil pressure, and I feel that the oil pressure is to blame for my leaking issue. I have already ported my oil filter housing, which did help. Prior to porting, I easily would reach an excess of 100 psi when getting into the throttle, this was not even close to red-line either. Now it generally stops around 90 psi, and maybe creeps up to 95 when I approach red-line.
I know the balance shafts have been eliminated on these cars thousands of times now, and I was hoping someone could possibly give me some insight on this issue since I am definitely not the first to encounter it. I have not yet been able to pinpoint where oil is leaking on the timing side, perhaps the high oil pressure pushed out the cam seals slightly and oil is now slowly seeping by? Other than the seals, I'm not sure what else where the oil could be coming from.
The only other possibility I have considered is that I am getting a bit of crankcase pressure. Has anyone seen a wet timing belt as I have described from a leaking valve cover or oil pan?
Thanks for any help, I have been trying to sort this out for some time now.
